Whats my best option?
18 Jun 2018
Hi Guys,
Looking for some help and support with a graphics card upgrade to suit my build. When I first put the build together 12 months ago I hoped to bag a 3060 or 3070 once rhey where released but that didn't happen.
Now I don't know what my best option would be? should I hold out for a 3060 or 3070 or maybe look at a 6700 or 6800Xt I don't know if they are comparable or not but seem a little more likely to find. Or is there another option?
What would you suggest with my current build?
MSI MPG Gungnir 110R Mid-Tower ARGB Gaming Case - Black Tempered Glass
Corsair RM Series RM850 850W '80 Plus Gold' Modular Power Supply
AMD Ryzen 7 3700X Eight Core 4.4GHz (Socket AM4) Processor
MSI Rainbow ARGB PWM Performance Case Fan with Controller - 120mm - Triple Pack
HD-56L-WD WD Blue SN550 1TB NVME M.2 2280 PCIe Gen3 Solid State Drive
HS-003-MS MSI MAG CORELIQUID 240R ARGB Performance Liquid CPU Cooler
MSI MPG B550 Gaming Carbon WiFi (AMD AM4) B550 ATX Motherboard
Corsair Vengeance RGB PRO Black 16GB (2x8GB) 3600 MHz AMD Ryzen Tuned DDR4 Memory Dual Kit
KFA2 GeForce GTX 1060 OC 6144MB GDDR5 PCI-Express Graphics Card
Whatever you can get as close to RRP as possible, is going to be the best value.
Are there any notable differences between the two? There seems to be plenty of 6700xts in stock for some reason? Is this because its a lot work?
I've seem a asus rog strix 6700 xt for £850 where most 3070s are £1000+
