What's on my paint work?
28 Mar 2005
hi all,
I've had the mx5 for a few weeks now, and over that time the door seems to be getting more white, it looks like water waters.
I have tried t cut, autoglym polish, a lot of washing and drying. And it just keeps coming back after I wash it.
Last thing I'm going to get today is a clay bar. But while I'm buying stuff has anyone got any thoughts?
Did you buy the car from a dealer? If not, how carefully was the car inspected before you bought it?
I gave it a look over, was a priv sale, was £800 and it's just for a road trip, I'm just being fussy and trying to polish it back out
The body work is fair from great
I'm wondering if the car has been hit side-on and that's a panel from a different car that's been resprayed. If the car has been hit, then what other problems lurk?
It'll just be shoddy lacquer from factory, it's a ~30 year old car after all.
As has been said by Si105, it'll want wet sanding at various grits but it's unlikely to actually fix it as I suspect the paintwork is just old an knackered. Only way to really fix it is to flat the whole car back and repaint / relacquer it but that's not a uick or simple fix.
When I said DA, I wanted to avoid the word "polish" to ensure it wasn't taken as "that'll hand polish out" as it wont.
I'm not too worried. Just wondered if it's anything could do with polish. It does get better when I polish but doesn't last more than a couple days
It would be worth having a go with some fine wet and dry (e.g. 1200+) used wet, followed up with some cutting compound. Even if it doesn't fix the problem it's not going to look any worse...
Is that British racing green/neo green? If so I don't think it has a clear coat on top assuming the paint is original.
I had issues with my one from a previous respray on the boot lid and one pop up lid. When water sat on the car it would draw out a white haze in the paint. Ended up like this -
I never tried anything more than hand polishing but the paint ended up crazing as well so I just swapped the panel over for one with good paint.
Tha
thats it!
One pop up lid, and both doors. If some is breaking one local to see I might swap bits but other than that it's only a little summer road trip car. I'm not to worried
Yeah, that's had paint at some stage then. It drove me mad as you can get it looking much better, then some moisture sits on the car and overnight, BAM. White again :p
You might be lucky though. I saw quite a few BRG doors come up while looking for a boot. Lids are very easy to find as people swap out for vented items.
