- 9 May 2007
hi i recently gotten a DFI p45 JR board and thought i try and push my good old dual core again
but first time i had acess to PLL and VTT voltages.
i did some research and it seems VTT can help clean up the voltage at high vcore. but what is PLL. and when should i consider raising these voltages?
should i raise them when increasing v core doesn't stabilize the oc?
also a bunch of other voltages like FSB and NB and SB, should i just leave these untill i get over 400 FSB?
edit- just found PLL and SB vcore is the same thing in my bios.
