What’s that temp/fan/core/voltage monitoring software called?
26 Feb 2004
Hampshire, England.
Hey guys,
What’s it called?
I’ve seen it loads of time in this forum but I don’t know the name of it :)
Cheers,
SW.
I personally don't use it as it never gives me accurate readings for voltages. But a lot of people do use it, so download it and try :)
Yeah that is the one!
Annoying you can't get it to run form staup tho :rolleyes:
Cheers,
SW.
Never personally found a program that monitors and reports rails correctly, even the BIOS. Do any of these programs do that or do they just pick up info from the BIOS?
Could never find that option myself, always ended up just making a shortcut and placing it in the Startup folder in the programs menu :) Then going into Configure -> Options and putting a tick on "Start minimized".
you can't get a reliable reading from the rails in software, it just can't be done with currents sensors.
a DMM will always represent the true value.
I know that they are never going to be 100% but it’s nice to have some sort of indication on your desktop. I used to use SensorsView with my Opty but that doesn’t seem to work too well with my new Intel :(
SW.
