Not bothered by looks, i go with performance everytimei have the coolermaster haf x bought it purly because every post/review i read said it was excellent for air cooled systems great airflow and so on, but depends on if you like the look of it http://www.overclockers.co.uk/showproduct.php?prodid=CA-203-CM&groupid=701&catid=7&subcat=
I was actually looking at that case, it does seem pretty good. Is there any worth while mods like extra fans i could put it, or is it ok.
It is OK without extra fans but has brackets built in for extra fans behind the HDD cage. I added some notua ultra quiet fans there and added reistors to the two 22/24cm (I can't remeber) exhaust fans built into the top pf the case which kept efficiency whilst reducing noise slightly. I really like this case.
whats wrong with the way the haf x looks lol i like it!
i would also say the antec 1200.
never owned one but by looking at the fan set up i would say it is superb for cooling.
