I don't have all 4 fans yet. I only have 2 and use them as top exhaust fans currently. The case you see here is the Cooler Master HAF912 which is what I use. Out of all 3 setups, what do you think will provide the most optimal cooling?
Setup 1:
Two 120mm fans at the bottom front of the case for intake and two 120mm fans at the the top of the case for exhaust.
Setup 2:
One 120mm fan at the bottom front of the case and one 120mm fan at the left side panel of the case for intake. Two 120mm fans at the top of the case for exhaust.
Setup 3:
One 120mm fan at the bottom front of the case for intake, two 120mm fans at the top of the case for exhaust and one 120mm fan at the top rear of the case for exhaust.
Setup 1:
Setup 2:
Setup 3:
