Whats the best in-car system?
1 Dec 2011
SW3
Ive been looking at a few on halfords and other online places and they all seem to do the same, is it just down to looks?
I want one that has bluetooth, usb and aux, either satnav thats built in, or atleast capable of accepting Avic gps unit, cd/dvd aswell.
Does anyone have any personal recommendations?
Its going to be fitted into a 08 Astra.
Here one ive been looking at just for an example.
http://www.halfords.com/webapp/wcs/...duct_Details_Zone_1-_-Blank&iozone=PDPz1#tab1
budget is around £450 give or take a bit more.
Thanks
Thanks
That isn't bluetooth compatible:
Bluetooth compatible: No
■Detachable Faceplate: No
■Display Colour: RGB variable
■DVD Player: Yes
■DVD/DVD-R/-RW, R/ RW Compatible: Yes
■Front AUX: Yes
■Made for iPod: Yes
■MP3: Yes
■Remote Control Included: Optional
■SD Card Slot: No
■USB Port: Yes
■DVD Player: Yes
■Front AUX: Yes
■Made for iPod: Yes
■MP3: Yes
■SD Card Slot: No
■USB Port: Yes
I know, i used the link as an example so people knew what i was talking about :)
The only thing I have to recommend is make sure the stereo you pick can read from sd cards, single handedly its the best feature I've ever had on a car stereo :D
I remember reading about these ages ago, I think it will probably hit the spot for you.
http://www.ebay.co.uk/itm/NEW-VXMMI...0?pt=UK_In_Car_Technology&hash=item33691d8d90
If I remember correctly they were raving about them on a couple of the vauxhall sites. I think it has a version 2 as well. There used to be a website where you could spec it up with TV addons / reverse parking senser cameras, all sorts. I'm struggling to find anything beyond ebay now though.
**EDIT**
Found it. http://www.ttints.co.uk/vauxhall/Vxmminew.html If you scroll down you can see just how much you can tag on to it.
It has the added bonus of being directly plug and play as well. Not a single wiring adapter is needed as I understand it. It's worth bearing in mind as when I fitted an oldish JVC unit into my Astra G I ended up spending the best part of £40 on ISO and steering wheel control adapters.
I think it should also flush mount against your existing dash surround and needs no blanking plate at all. Another small bonus.
Do not buy from Car audio centre they are con artists...
Car audio direct or Car audio security only.
Personally for what you want pioneer is the only make id stick in my car. Kenwood at a push.
