- 18 Apr 2003
- England
Maybe a little technical here, Im still learning myself.
I just got a soundcard & speakers & am finding music is missing some frequencies; either too much bass boom or not enough mid tones.
I cant seam to get it right.
Also Im noticing a sort of squelch effect where the volume automatically drops after a low frequency sound (this happened after installing the soundcard).
Im reading up on this & have learned my speakers have a fixed crossover of 120hz (indicating the sub does a lot of work) but THX specs require 80hz (as the speakers are THX certified).
Moving the crossover slider in the soundcard drivers creates more or less bass but im struggling find the best compromise.
Does anyone have the same speakers & have found the best crossover frequency or should I just not use the function?
Hope these aren't too many noob questions.
thanks
Soundcard:
Xonar HDAV1.3 Deluxe
Speakers:
Logitech Z-5500 THX Certified 5.1
thanks
Soundcard:
Speakers:
