Hi there,
What's the best mobo on the market for Crossfire setups?
I am currently using a 945 Intel setup - Only compatible with Intel based 945/955/975X series mainboards
The problem I am finding is that the motherboards at the moment all have bits n pieces which I would never use and would probably amount to overkill paying for it. In saying that, I see mobo's which are crossfire compliant being used for Core 2 Duo etc - which isn't what I need it for. (I already have a C2D computer setup but that's not relevant)
I would appreciate anyones advice/suggestion on what's the best crossfire mobo for a 945 processor.
Many thanks!
EDIT: In the clearance section I noticed this - let me know your thoughts:
Asus P5WDG2-WS Extreme Intel 975X (Socket LGA775) PCI-Express Motherboard - OEM (MB-188-AS)
Many thanks!
