Hey there guys.
What are the best settings for video capture for the best quality for the lowest size, and minimalizing performance hit when recording?
I don't know a lot about compression apart from if you compress it then it usually lowers quality a lot, and with my 1mb upload speeds, it takes hours to upload a uncompressed 2gb 60 second video to youtube
So rather than editing a uncompressed clip etc, is there any decent way to set it up so it does it whilst recording in the best possible way rather than turning the quality slider down? because that makes it look terrible and still quite a heafty size even when its set way down to even %50
cheers
Also, don't know if this is the right section of the forum to be posting in, but I guess its to do with the gpu and afterburner so I figured it should go here
cheers
