Toothpaste is actually quite good until it turns into a solid which will be in quite a short time.
Artic silver 5 or ceramique are both as good as each other really - I tend to use as5 on IHS but ceramique on bare silicon. I recently made the switch to shin-etsu.
Testing @ 3.7ghz 1.45v
Ambient temp of 18c for the AS5 - 20c for the shin-etsu.
I didn't feel the need for multiple mounts as mounting a d-tek fusion is idiot proof tbh and very difficult to mess up aslong as you tighten the thumbscrews diagonally 1 turn at a time.
Temps before (Arctic silver 5) = 44c Full load (after 12hrs Large FFT's)
Temps after (Shin-Etsu) = 41c Full load (after 12hrs LargeFFT's)
A nice 3c drop on load, also bear in mind the shinEtsu was working with a higher ambient temp and has not had the '200 hours' AS5 suggest for 'setting'.
An impressive drop for £2 imo.
The compound itself though is a pain to work with. Its not at all like AS5 which incidently isn't exactly a dream to work with either. This stuff is more like a 'paste' than a 'liquid' therefore the spreading method(via razorblade) which I prefer is a little more difficult to get a thin layer as it seems 'drier' than the as5.
Temps though speak for themeselves so I would go with it over As5 and will do so in future builds aslong as its available.
There is however NO mention of it not being conductive/capacitive so I would assume it is. No squirting it all over the motherboard then I guess
![Roll Eyes :rolleyes: :rolleyes:](/styles/default/xenforo/vbSmilies/Normal/rolleyes.gif)
