I used to have an AMD R9 390 Graphics Card and it broke on me a couple of months ago. After thorough testing I have found it is definitely the graphics card so I am looking for a replacement.
I understand that my build is quite dated now but I would prefer to keep it for a good couple of years (if I can) considering I do not play any high-end games. I only play games such as CSGO, Rocket league, Valorant. I would like to be able to play Escape From Tarkov smoothly as well.
So far I've done quite a bit of research of which would be the best graphics card to go for based on my build but I'm still stuck for what to go for – please see my options and where I am below:
- 1080ti ? Costs around £450 second hand – cannot buy brand new any more.
i7-4790K with 1080ti comparison link - https://www.cpuagent.com/cpu/intel-...vidia-geforce-gtx-1080-ti?res=1&quality=ultra
- 1660ti ? - Costs around £380 brand new
i7-4790K with 1660ti comparison link - https://www.cpuagent.com/cpu/intel-core-i7-4790k/bottleneck/nvidia-geforce-gtx-1660-ti
- 3060ti ? – Costs around £550 brand new
i7-4790K with 3060ti comparison link - https://www.cpuagent.com/cpu/intel-...vidia-geforce-rtx-3060-ti?res=1&quality=ultra
Or should I look at AMD based on the build I currently have?
My old card costs around £160 second hand, and that's for the slight upgrade from R9 390 to R9 390X. Worried this will struggle with running Escape from tarkov on high frames though and I want the pc to last me a good couple of years at least.
This is the current build and I run on 1440p :
[CARD DIED – LOOKING FOR REPLACEMENT] - MSI Radeon R9 390 GAMING AMD Graphics Card 8GB
Intel Quad-Core i7-4790K
EVGA Super NOVA 850W PC Power Supply – Gold
Gigabyte Z97X-Gaming 7 Intel LGA1150 Z97 ATX Motherboard (4x DDR3, 6x USB3.0, 6x USB2.0, HDMI, DVI-I, DSUB)
Crucial BX100 250 GB 2.5-Inch SATA III Internal Solid State Drive
WD 1TB 3.5 inch Internal Hard Drive - Caviar Blue
Alpenfhn Matterhorn Pure Edition CPU Cooler 120 mm
NZXT H440 Mid Tower Case with Side Window and 4 Quiet Fans for PC - White/Black
Team Group TLRED316G2400HC11CDC01 - TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual
ASUS MG278Q Gaming Monitor - 27" 2K WQHD (2560 x 1440), 1ms, G-SYNC Compatible, up to 144Hz, FreeSync
From my research (partially based on those comparison links above with an i7 4790K) it seems that the 3060ti would give me best performance and the price difference is not huge compared to the other options out there which are available today.
However, I am wondering if those comparisons are based on running at 1080p (I will be running 1440p) which I have gathered means more load on GPU, but no more load on CPU for 1440p compared to 1080p - would this mean the bottleneck won't be that bad with 3060ti + i7-4790K?
I am also open to exploring upgrading the CPU as well but I think I am limited with this due to my old motherboard. It also gets to the point where if I am upgrading multiple parts, I may as well start looking at a new build but that’s not really what I can do at the moment.
Anyways I'm just exploring all options so I'd appreciate if any of you have a suggestion based on the above. Many thanks,
my 980ti just decided to poop itself. Now it is a posh paperweight. Also in the same situation as the OP and looking at my options. Holding out before doing a full system upgrade as the refresh isn't too far away.
