Whats the best way to go?
13 Feb 2004
Sealed in my Sarcophagus.
Ill be having about £800 quid soon to spend on hardware so i need some advice regards intel setups. Im a techie by trade but ill admit im out of the loop regarding intel setups.
In my work i dont do much system building anymore so i dont have a wide range of gear to tinker with like i used to a few years back. My current system is a 939 x2 4400+ with 2 gig of ram and a 8800GT.
Ive just bought some nice fast large samsung SATA drives so im sorted hard drive wise. Im also intending on keeping the GT for now, until the new cards come out and we see how they perform and what prices they go for. My case is also being kept as its big enough and nice enough to do me for a long time yet.
My power supply is a Tagan 480watt ( i think ) but ill be keeping the old parts and making a backup system for the girlfriend. I have a spare 7800gtx for that as well :p
So really im after a new mainboard, cpu and ram. I have a Noctua NH-U12P CPU Cooler so i assume this will do for now. Temps in the case are very low due to lots of room and large slow speed fans blowing unhindered right over the cooler and out the back.
I will also want a SATA optical drive but those are cheap anyway so really im after a good quality STABLE and hastle free intel CPU MB and RAM combo.
I can stretch to DDR3 ram if its going to be worth keeping for the future ( doubtful ) and i want a minimum of 4GB of ram with upgrade possibilty to 8GB. So that means 2x2gb sticks.
The machine is used for general use as well as gaming with Age of Conan being the latest passtime!
I have a dell 20" widescreen which does me fine so gaming is at 1650x1050. I also would like a good vista 64 compatable sound solution, preferably not onboard unless its very good.
I already have an unused oem vista business ( 64 ) ready for this machine so thats covered.
Im of course considering the q6600 chip but i believe there are new intel cpus and chipsets on the way? should i wait for them to appear or is it another case of an evolutionary step rather than revolutionary with them?
Im only asking here as quite frankly there is a bewildering array of chipsets and motherboards/cpu's now and its hard to decide which is best for stability and reliability.
Spec away!
/thanks
The new cpu and chipsets you're talking about are, I assume, Nehalem. They are a while away still. They are revolution rather than evolution, offering a similar step up as core2 was from the previous gen.
So if im ok with what i have now i may as well just wait another 6 months and go for the new stuff? i suspect they will be vastly overpriced however and then of course you are dealing with 1st generation mainboards and all the problems that usually go with that.
Ok so lets assume im going for a current gen system. What chipset is the most stable and overclockable... im not fussed about SLI but its something i wouldnt rule out.
As i said before what i really after is the most reliable, stable board that will take all the current chips AND happily run 4x2GB DDr2 ( or ddr 3 ) on vista 64.
P35 boards are good overclockers. The abit ip35 (pro) is meant be very good. The P45 has just been released to replace it though.
The X38 boards are good overclockers as well, they have two 16X pci-e lanes for full crossfire (unlike p35s). The X48 are the step up from X38 and cost a fair bit more.
Nvidia 7 series boards are the only boards that support sli, but they aren't great overclockers. Stay away from nvidia 6 series boards.
Ive had a mooch round and come up with this. Thoughts?
OCZ 4GB DDR3 PC3-10666C7 1333MHz Platinum (2x2GB) Dual Channel DDR3
Gigabyte GA-X48T-DQ6 Intel X48 (Socket 775) PCI-Express DDR3 Motherboard
Intel Core 2 Quad Q9450 LGA775 'Yorkfield' 2.66GHz 12MB-cache (1333FSB) Processor - Retail
Comes to 585.41 inc vat and delivery.
The only thing im not sure about is the cpu. IS it worth sticking a much cheaper dual core in for now and a better cpu later when they appear? Also im not 100% sure my noctua will fit this board, from the reviews and photos ive seen it should clear the mainboards heatsinks if placed side on.
Also if i spent the extra and got 2 lots of the RAM ( so i had 8gb ) would this board have issues?
