What's The Best Way To Overclock This System?
18 Oct 2002
Newcastle
I have recently bought and built the rig below, but I'm slightly confused about how to overclock it correctly. FSB and multiplier don't appear to be the only options anymore. Can anyone advise me on the best method?
X2 3800+
2GB DDR400 Corsair Value
Asus A8N-Sli SE
Leadtek 7800GT 256MB
Cheers guys and gals. :)
Set the HTT multiplyer to 4x, that will give you a max FSB of 250 (basically dont let the HTT go over 1000mhz)
Other than that it is just the FSB, multiplyer, deviders and voltages.
Deviders runt he ram slower than default so you can increase the FSB more than your ram would normally allow (setting to 166mhz is the best bet to begin with) and voltages are obvious.
