Order a kit from this guy he really knows his stuff check out some of his videos he does this for a living now working at a prestige car dealership & offers no nonsense DIY for free at home advice!! I have bought several kits from him his Pearlescent colour match is 100% & he also supplies a fast drying clearcoat (gloss enhancer he calls it) so you should easily be able to DIY conceal this within a short amount of time!
Paint Gear Online specialise in the methods, materials and processes of paint touch ups, scratch repairs & chip work repair to maximise your cars aesthetic potential. Minor damage and stone chips are unfortunately inevitable... that's why we here at Paint Gear Online manufacture and supply the...
www.paintgear.co.uk
The 1 Finger scratch repair video!A YouTube 1st for this simple method that literally anyone can do!The method shows how you can vanish or massively improve ...
www.youtube.com
A short video explaining how to remove medium to deep scratches from your bumpers.Wet Sanding and polishing techniques used.Like, comment and subscribe.****L...
www.youtube.com
A step by step tutorial of a very effective method to remove DEEP paintwork scratches that CANNOT be removed by sanding and or/polishing alone!Using solvent ...
www.youtube.com
It's pretty much the same technique:
1: If you cannot buff out with polish (after the dripping water test to see if it goes away = clearcoat only layer damage).
2: Gently wetsand with 2000 grade paper.
3: Carefully using the supplied brushes in his kit paint over the damage building it up in layers letting it dry 10 mins between coats.
4: When its level with the other paintwork wetsand again.
5: Buff & polish depending on the damage you may also need to use the supplied gloss enhancer product (he supplies everything in the kit).
I cannot praise this guy highly enough he is very straightforward & honest about it & saves you a LOT of money for effectively nothing as you do not even need his product you can source your own for slightly less but he supplies the lot in an easy to re-use kit should you ever need it again for stone chips.
Read some of the comments on his channel he has helped so many people from all over the world his techniques really work & are so straightforward!
Far cheaper than paying a bodyshop to paint that area then try to conceal & buff away the difference with clearcoat blowing further onto the panel!!!!
