whats the better gfx card
Permabanned
28 Aug 2006
Manchester-UK
hi all :)
just got back my old 9800se vid card and im currently using my dads 7100gs gfx card.
im just wondering what ppl think it the better card to use the nvidia 7100gs or the ati 9800se vid card?
thx :)
I reckon the 9800 would probably have an edge, don't know too much about the 7100 though. But as suggested above why not just try them both and use whichever works best in whatever game(s) you're playing?
Dureth said:
Don't forget the 9800se was the 4 pipe version with 128bit memory interface (the 9800pro was 8 pipe and 256bit).
Still got my 9800pro (flashed to XT) in another rig, what a card, so far ahead of the NV FX range at the time.
There were 256bit 9800SEs as well, and often you could re-enable the 4 disabled pipes at driver level if you had the right sort (typically L shaped memory chips).
