Celeron to P4 upgrade, need help..
Is it just cache or is there more to it. I'm upgrading my laptop from a 2.0Ghz Celeron to a P4 of 2.2 or 2.4 depending what I can find and I was wondering what the actual difference in the chips is.
Also, the chip I've got in mine looks similar to this:
But there are some that look like this:
My question is: can the cover thing be taken off? If so, would it then look the same as the one in the top image. I only ask this because the cooler on my laptop seems to be designed for chips without the cover.
hope you can help
cheers
P
hope you can help
cheers
P
), it is designed for desktop-replacement laptops. The IHS is clued onto the core so chances are you won't be able to remove it without damaging the core. Even if you managed to remove it you can't be sure if it will work on your laptop or if the cooling design will cope with the excessive heat.
. Yeah it happens with all mobile P4s when used on a desktop chipset; the multi will be fixed @ 12 and the speed is default to 1.2Ghz.
. If it is a desktop chipset your laptop is using then there is no fix if the chipset doesn't properly support MP4-M cpus.
!! I'd check CPU-Z to see the what vcore your cpu is running first.
