- 4 Nov 2004
Long story short, I was using an 8-pin splitter for my 3080FE and seeing shutdowns. Moved to two separate cables, and all is now fine.
What I'm struggling to find now is a really good explanation as to why - there's a lot of posts out there taking it as common knowledge.
It *sounds* to me like the PSU is cutting out (presumably to protect itself) - but protect against what?
- The gauge of the wires is ample for a single cable, so I don't think it's temp
- The SF750 has a single 12V rail, so I don't think it's over power (especially as fine with two cable)
- I don't think there's per-plug monitoring on the PSU
