What's the difference between these CPUs?
15 Jan 2009
Merthyr Tydfil
I was wondering what the performance difference was between the i7 930 (1366) 2.8Ghz and the i7 860 (1156) 2.8Ghz?
Which one would be best for gaming?
I7 930 = Triple channel memory
I7 860 = Dual channel memory
Both would be very similar in gaming
If you where to go 1366 socket save some money and get a 920.
The key factor in looking at both is the 1156 mobo's are a fair bit cheaper then 1366 if you are not after all singing all dancing ones. Where as the cheapest 1366 mobo's are around £130.
Basicly as the 920 is a lot cheaper at the moment id say go that way.
Thanks for the reply.
The mobo for the 920/930 is Gigabyte GA-X58A-UD3R @ £157 and the mobo for the 860 is Gigabyte GA-P55A-UD4 @ £155. Not much between them.
I’ve noticed on CPU comparison charts that the 860 is above the 920, I was just wondering why.
I’ll probably go for the i7 930 and GA-X58A-UD3R mobo (if I can find a suitable powersupply).
Cheers.
