whats the difference between these xspc rads?
20 Sep 2011
local
The xspc rx series and the ax series?
I will be adding my gfx card to watercooling and i currently have the rx 240 for just my cpu,but would I be better off with a 360 ax or rx in the roof and/or a rx240/ax240 in the front ?
according to the results thinner rads can perform well at slow speeds!
Thats what I'm not to clued up on,generally is it thicker rads for higher speed fans and thinner rads for slower speed fans or vice versa?
AX is for if you are space limited or are looking for an easy paintable radiator mod, RX is their flagship performer.
ok i see now! Its definitely the rx route for me then,I have the rx v2 240,i want to add the rx 360 to the roof ,would i be better off replacing my rx240 v2 with a rx240 v3 and getting a rx 360 v3 for the roof,or just add a rx v3 360 and keep my current rx 240 v2?
No point replacing what you already have, just get the 360 in addition.
