what's the difference between these?
23 Jan 2007
Glasgow
Hi
had ordered a MB which has gone out of stock, it was
MSI P67A-GD65 Intel P67 (socket 1155) DDR3 Motherboard ** B3 REVISION **
http://www.overclockers.co.uk/showproduct.php?prodid=MB-165-MS&groupid=701&catid=5&subcat=1906
so i need to pick an alternative and have been looking at this
MSI P67A-GD53 Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
http://www.overclockers.co.uk/showproduct.php?prodid=MB-170-MS&groupid=701&catid=5&subcat=1906
can anyone tell me the difference between these?
i have these parts on order also, and want to make sure the alternative MB will be compatible
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail [BX80623I52500K]
https://www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN
and
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) [KHX1600C9D3X2K2/8GX]
https://www.overclockers.co.uk/showproduct.php?prodid=MY-094-KS
thanks
The GD65 has Dual BIOS, 2x IEEE 1394 Firewire, 4x USB 3.0 ports, 2x eSATA ports, 4x SATA 6Gb/s ports with RAID.
Your CPU will be compatible with it.
That ram is 1600Mhz, but the motherboard specifications say "4x DIMMs with support for DDR3 1133/1066 up to 16GB MAX", so I'm guessing you'll have to set the speeds manually?
does this meen its not compatable? :(
Its compatible, its naturally set at 1333mhz as thats the standard speed of the sandybridge memory controller, just either run at that speed or just set the RAM multiplier to make it run at 1600mhz.
