Hi guys
I'm looking to buy 2G of memory and want something that will run in SLI mode and also give me bang per buck in the long term, I use my pc for gamming
Both produced by OCZ, the first one listed seems to have a higher voltage and also can be water cooled but is that it ????
Will they both run at the same speeds
OCZ 2GB (2 x 1GB) PC2-9200 1150MHz Passive/WaterCooled Dual Channel DDR2
http://www.overclockers.co.uk/showproduct.php?prodid=MY-084-OC&groupid=701&catid=8&subcat=817
OCZ 2GB (2 x 1GB) PC2-9200 1150MHz Reaper HPC Edition Dual Channel DDR2 (OCZ2RPR11502GK)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-089-OC&groupid=701&catid=8&subcat=817
Pc Spec
Intel Core 2 Duo E6850 "LGA775 Conroe" 3.00GHz
Asus P5N32-E SLi nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
BFG GeForce 8800 GTX OC 768MB GDDR3
Antec P-180
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
Seagate Barracuda 7200.10 500GB ST3500630AS SATA-II 16MB Cache
Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB Cache
Razer Tarantula Advanced Gaming Keyboard - Black
Razer Diamondback
Dell Ultrasharp 2407WFP 24" Widescreen LCD Monitor
Pc Spec
Antec P-180
Razer Diamondback
