- 11 Mar 2005
Apologies, I'm definitely more of an end user than a techy - but any help gratefully appreciated!
I'm looking at purchasing a new machine - nothing too fancy - but I don't want something that is useless either!
My current machine is a dell inspiron 9100 P4 3.6 etc... and up until recently was working brilliantly - its now throwing a clot every time I start it up and shut it down... I've switched the memory to no avail... as its out of warranty, I thought it was time to get rid!
Although, I'd like to build my own machine - at the moment I havent got £1000 to spend in one go! Mortgage to pay and all that... so...
I've seen a *waits for flames!* another Dell machine, a desktop this time which appears to suit my needs... moderately high spec.. but I'm puzzled...
If i select a Viiv C2D i'm unable to select Windows XP Professional (which I'd prefer over vista for the meantime anyway) or... if I select XP Media Centre I can have either the C2D or the Viiv C2D...
I suppose, what I'm asking is.. what is the difference between Viiv and C2D??
The spec I'm looking at is C2D 2.4GHZ , 2GB ram, 500 gb hdd (2 * 250) with an ATI Radeon X1300 Pro..
I do a lot of CAD in work for which i use my precision workstation (i think I'm a dell salesman!) which is specced up to the nines - but as my current system will run the latest release of AutoCad / 3DSM i have no reason not to think that this new system couldn't last a few years?
Anyway - apologies for EXTREMELY long post - any advice would be great...
In the meantime, I'll do a search in software for vista vs xp and see what comes up..
Cheers,
Tom
Cheers,
Tom
