whats the difference?
25 Nov 2007
London
between these 3 cards
http://www.overclockers.co.uk/showproduct.php?prodid=SC-044-CL&groupid=701&catid=11&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=SC-045-CL&groupid=701&catid=11&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=SC-043-CL&groupid=701&catid=11&subcat=
would be good to save 40 pounds and go for the xtreme gamer or xtreme music etc..
also does the software work nicely with vista 64 bit, ive gone back to xp cause i was ****** with vista 64 lack of software for the audigy 2 zs, mabye i will go for the onboard audio?
EDIT: What card Works perfectly in Vista 64!
The X-Fi XtremeGamer Fatal1ty Professional and the X-Fi XtremeGamer Are the Same
But the Professional has the Break out Box (front Panel)
X-Fi XtremeMusic 7.1 is the older version of the Gamer. some people say the Music is the better Card out of the Two
Edit: as far as i Know a lot of people Have problems with the Drivers in Vista 64bit but others are Fine
cheers raiden, im confused why the fatal1ty one doesnt say it had front panel. dont have any room for it :D
think i will go for the xtreme gamer when i order my monitor eventually
