What's the easiest way to add another ethernet port?
2 Jan 2004
Chesterfield
I have my Sky router near the TV and am currently using the 4 ports for my PS3, WDTV Live, NAS and homeplug to pipe the internet connection to my PC upstairs.
The trouble is I could do with a couple of extra ports to feed a new TV and my Sky box but I could do without having to power another hub behind the TV!
Is it possible to add a couple of extra ports without a powered hub??
An ethernet splitter? Although, I don't think they're recommended.
Something like this,
Ethernet splitters are designed to be used with one at each end of a single piece of cable. They can work because for a 100mbit Ethernet connection only 4 of the 8 wires in an Ethernet cable are used. Using the splitter at each end assigns the second port to the unused 4 wires. However gigabit transfer rates will not be possible with these.
In short this will not do what the OP wants as it's a solution to effectively running two cables in one, not adding more ports.
Thanks for the replies guys!
I was afraid I'd end up having to plug in a switch/hub (whats the difference??) but it looks like thats the only way I can do it I guess!
So in respect of the gigabit one above, I assume I just pipe one of the existing ports into the switch and then I can use the rest of the 4 as I wish??
Thanks again....
In short, switches are intelligent and route traffic to the devices that need the information, hubs just transmit whatever they get to every port and the host on the end decides to ignore or accept the frames. Tbh i don't even know if you can get hubs anymore. Essentially it's less collisions and more bandwidth per device with a switch.
