Whats the highest flowing 12v fan. Noise not an issue
22 Dec 2002
Minehead
Hey guys,
Looking for the highest CFM fan possible. 140mm max ideally as its got to go somewhere where space is a slight issue. Not for cooling a pc per se but to cool a turbo charger in an engine box!
Thanks for any help :)
Mike
What about the 5400rpm Scythe Gentle Typhoon?
http://www.overclockers.co.uk/showproduct.php?prodid=FG-032-SY&groupid=701&catid=57&subcat=4
Not in stock though. Serious airflow and serious noise. You'd have to be hard of hearing to be able to stand the noise of this beast, even at 5v.
Code:
- Maximum air flow, CFM ±10%: 150.1
- Maximum noise level, dB(A): 50.5
- Maximum fan speed, RPM ±10%: 5400
- Power Consumption: 13.68 W
- Rated Current: 1.14 A
- Starting Current: 2.69 A
Don't put it on a motherboard header!!
Lol delta I had a 80mm delta years back, WOW that shifted some air and was very loud but it kept my celeron 600mhz @1ghz :)
http://www.firingsquad.com/hardware/celeron600oc/ Happy days :)
Yer the power was immense
Hey guys,
Mike
Got a picture? Can you not fabricate something to hook up to the 'tight' area so you can have a bigger fan externally, that then feeds into the box?
Code:
http://www.youtube.com/watch?v=tlDv0XL5bv8
You're not kidding!
