What's the important point for a 3d printer beginner
3 Nov 2022
HONG KONG
As a beginner, when you prepare to get a new printer, what's the key point, speed? enclosed? core xy? Marlin or klipper?and screen? price?
First question will be Filament or Resin, second will be budget. These answer will dictate the level of function and reliability of your choice
Ok I am explaining your query points here:
Speed: The speed of the printer will determine how quickly it can produce a print. If you plan on using the printer for small, simple projects, a slower printer may suffice. However, if you plan on using it for larger or more complex projects, a faster printer may be necessary.
Enclosed: An enclosed printer will help maintain a consistent temperature and humidity level, which can improve the quality of your prints.
Core XY: This is a type of printer design that can provide faster, more precise movement of the print head.
Marlin or Klipper: These are firmware options for the printer. Marlin is a popular choice that is easy to set up and use, while Klipper offers advanced features such as multi-extrusion and faster printing speeds.
Screen: Many printers come with a built-in screen that allows you to control and monitor the printer's settings and status.
Price: The price of the printer can vary widely, so it's important to set a budget and consider how much you're willing to spend. It's also important to consider the cost of replacement parts and consumables such as filament. Ultimately, Check these models of your specific needs and preferences when choosing a printer, and to do your research to find a best suits those needs.
