whats the lowest cpu cooler that will work with a 2400g/3400g?
9 Jan 2016
Derbyshire
im thinking of going tiny mini itx system over building a system in a spare M-atx cube i have which obviously limits what i couldve done which id be happy to compromise, but couple cases ive seen im not sure how suitable for an APU they would be and aside from they would require a pico its the cooler height im doubting.
i would get an M.2 drive, so there would be no need for any hard drive brackets or hard drives for that matter which should allow a little taller of a cooler.
anyways these are the 2 cases ive seen so far that i like the look of
E-H60 Mini Computer ITX Case Aluminum Alloy HTPC Small PC - Dimension: 200*60*200 mm (W*H*D)
HTPC 2.0 USB Gaming Power Supply Metal Chassis Computer Case Mini ITX M01, M03, M05(unbranded case) - Size: about 205 x 190 x 60mm
they are clearly not stuff you can just buy anywhere and are probably old compared to other cases, but as long as they work its not of any bother to me.
basically im just trying to find out if these sort of cases would even be usable with a Ryzen.
Stock cooler? Or any of the £10-15 jobs. My mate had the wraith stealth with 3600 in a crappy case with 0 airflow and yeh it ran a bit hot and wouldn't overclock it but it should certainly run just fine on stock (maybe little undervolt).
There are some low profile coolers too, could do alpine 12lp or try measure alohenom ridge (47mm)
