Deleted member 68110
I'm after a machine to hook up to a TV for Zoom calls and I was hoping people might be able to help me determine what the minimum spec is that I could get away with while still getting maximum Zoom meeting performance...
System Requirements:-
From that it looks like I need a 6th gen i5 and 4GB of RAM.
I guess my question is what, if any, performance increase will I notice if I go above those specs?
Microphones and headsets
I'm after the oldest lowest spec processor and ram I can use.
Any help would be great.
I thought I'd try and collate what info I could find so it might help anyone else looking for the same details.
Here Zoom state their minimum spec:-
https://support.zoom.us/hc/en-us/articles/201362023-System-requirements-for-Windows-macOS-and-Linux
In terms of working out min spec for max performance, it seems the processor needs to be beefier for different virtual background settings:-
https://support.zoom.us/hc/en-us/articles/360043484511-System-requirements-for-Virtual-Background
The punchiest is for "Video without a physical green screen":-
Processor and RAM requirements
Minimum Recommended
Processor Single-core 1Ghz or higher Dual-core 2Ghz or higher (Intel i3/i5/i7 or AMD equivalent)
RAM N/A 4 Gb
Notes:
- Dual and single-core laptops have a reduced frame rate when screen sharing (around 5 frames per second). For optimum screen-sharing performance on laptops, we recommend a quad-core processor or higher.
- Linux requires a processor or graphics card that can support OpenGL 2.0 or higher.
- Zoom desktop client for macOS, version 4.6.4 (17383.0119) or higher
- macOS 10.9 or later
- Supported processors (720p video)
- Intel i5, i7, i9, Xeon - 4 cores or higher
- Intel i7, i9, Xeon - 2 cores, gen 6 or higher
- Intel i5 - 2 cores, gen 6 or higher, and macOS 10.14 or higher
- Other Intel processors - 6 cores or higher, except Atom and Y series
- Non-Intel processors - 8 cores or higher
- Supported processors (1080p video)
- Intel i5
- 4 cores or higher, gen 5 or higher; or
- 2 cores with gen 7 or higher and 2.0Ghz frequency or higher
- Intel i7 - 4 cores or higher, gen 2 or higher
- Intel i9, Xeon - 4 cores or higher
As an aside, it would also be good to know if anyone has recommendations for decent value microphones and decent value, low-profile wireless earphones and microphone combinations.
I have a pair of SteelSeries gaming headphones which have good sound and a decent mic, but they aren't very well suited to company meetings because they're too big and intrusive - are there in-ear headphones that have good sound and a decent mic?
