Whats the smallest case you'd use if.....
30 Sep 2006
Midlands, UK
....you had an intel E2160, a Gigabyte P35c DS3R mobo, 2Gb Geil PC6400 ram, 250Gb sata hdd, 1 x dvdrw, and a 7900GS (if i could find one as OCUK don't seem to sell em anymore ???)
...and.....you wanted to overclock it?
Could a SFF case take the extra heat from overclocking do you think? I would probably put a freezer pro 7 on the cpu just to cool it better than the stock HSF.
I'd like to get the cores running nicely at about 2.5Ghz, don't need to max it out by pushing for 3Ghz.
your advice is appreciated, thanks. :)
