I like the graphic on the left hand side http://katielou.blog-city.com/ what should i be googling for? as id like to do something similar with a characture of me like that. And what about the random patters as well?
It won't be as good quality or professional as if you traced the vectors in Illustrator, but if you want a quick result it might be worth a look.
Edit: The above might not work, it kind of depends on what image you're dealing with. But with the correct colour choice you might achieve something.
