what's up with my NOD32?
29 Jul 2003
i get that everytime i boot up my laptop, NOD32 wouldnt startup properly, i had to click OK button and lanuch the NOD32 manually. reinstalling NOD32 make no difference
HELP!
thanks
no_1_dave said:
Sounds like the Kernel isnt starting on startup.
Just re-install Nod32, it only takes 1 or 2 mins
wesley said:
http://img401.imageshack.us/img401/9996/nod32uo4.jpg
HELP!
thanks
If it were me, I'd completely uninstall NOD32, delete all of it's associated folders (if it leaves any behind), delete any files in your Temp folders, then run a registry cleaner (such as the one found in TuneUp Utilities 2007).
After doing that, trying installing NOD32 - could be a setting stray in the registry.
Have you checked to see the service is on Automatic and setup to start at boot with start, run, type "services.msc" ??
working now, thanks :)
