- 29 Dec 2004
- Shepley
I've had a Numark DM950USB mixer for some time now, but the crossfader has never worked- so I mix with the volume faders. To clarify, it is all plugged in inside but has no effect on the actual sound output in any position. It also doesn't crackle or make any audible noise when I move it so it appears to be completely dead. Will replacing the crossfader make it work or do you reckon it's a deeper problem? I only ask because the crossfader is fairly expensive to replace compared to the cost of the mixer so don't want to buy a new one for no reason.
