My Spec:-
Hardware
X2 4600
Mushkin xp4000 black sticks dual channel(2gig)
DFI LanParty UT NF4 Ultra-D (Socket 939) PCI-Express (latest bios)
Enermax Liberty 400W ELT400AWT ATX2.2 Modular SLI Compliant
Arctic Cooling Freezer 64 Pro
powercolor x1800xt with new zalman flower
36gig raptor
320gig drive
Software
Fresh install
Winxp pro
Cat 6.8
latest nforce drivers
latest sound drivers
I can't seem to make this stable in games when overclocked. Power will just suddenly die, no artifacts, no crash, just powers off.
I have looked through the DFI thread, its soo bloated, and i cant see anyone with my exact spec in there.
Now i dont consider this a high overclock for this spec, and my system is well cooled, even tried with a massive desk fan blowing straight into the case with all sides off, so i dont think temp is a problem.
Temps:-
CPU 35-58(LOAD)
Memory, warm to touch, with a fan right over it.
GPU upto 65 (under load)
northbirdge upto 60(although ive ordered a new cooler)
Hard drives, no more than 45 under full load
Overclock settings:-
FSB: 230 (ram ratio 1:1)
CPU: ~2.78
CPU Volts: tried between 1.375 - 1.5(over 1.5 windows crashes)
Chipset volts: tried between 1.5 - 1.6
LDT volts: 1.3 (htt running at ~980) should be ok?
Mem volts: tried 2.6-2.8 (also tried 2.9, but seems excessive as the mem is underclocked at present)
Memtest runs all tests fine even with minimal cooling over night
Prime95 runs for 5 hours with no errors
Also tried setting memory to 2T command just incase, but it still wasnt happy.
Im thinking that i should have gone for a bigger PSU, but i dont want to have to pay for a bigger one if i can get away with it, ive read reviews and it should support this system and even with more devices and also SLI on x1900s. I know these things could be 1 of hundreds of factors, but i purchased this system specifically to get a good overclock, and i want it to do 2.8 stable in games!
Hardware
X2 4600
36gig raptor
320gig drive
Software
Fresh install
Winxp pro
Cat 6.8
Temps:-
CPU 35-58(LOAD)
CPU: ~2.78
