Hi everyone,
Got a Merc A Class - the Diesel one (A170).
When it's placed under a heavy load, the engine just cuts out completely, which makes overtaking very erm, interesting
As an example, today on a clear road (40mph) I put the car into 2nd gear at about 15mph, and pressed the accelerator firmly (probably about 3/4 of the way). The car goes from about 1.5k rpm up to about 3.5k (which probably took 2 seconds to do) and then promptly cuts out somewhere between 3.5k - 4k. (And can I say the A class is a right **** to steer into a side road with the power steering cut out due to the engine cutiing out. Need both hands to turn the wheeel lol.
It's not just limited to heavy acceleration. When I was driving back home from uni (i.e had the back of the car loaded up with all my things) the car cut out 11 times on the 1.5hr journey home, one of those times was on the moterway at 60mph.
As some further info, when the engine has cut out, it wont start again for a while. If i turn engine off (i.e turn key all the way to left, put car in neutral, hand brake on, and then turn ingnition on, the engine just turns over. It doesn't catch at all, even if I pump or press the accelerator. Only solution i've found is to give the car 60 - 120 seconds before trying again and it usually starts fine then.
So - any ideas? I only have one light on the dashboard when the engine cuts out - think it says ECU from memory - really should take a note next time. Merc already put a new ECU chip in which hasn't done anything to the car - same fault.
This was after VW said it was fixed by the way lol.
