whats wrong with my connection
Permabanned
19 Oct 2007
im on upto 8mbit, the highest ive ever seen is 5mbit, yet on the weekends, its always cutting out if i sync higher than 3mbit, it will disconnect till i sync on a lower rate, i had to cut most of the log out to post:
23.07.2007 15:32:36 - C1L1D1T00 | BitrateDN: 5344 kbit/s | BitrateUP: 448 kbit/s | SNRM: 5.2 dB
23.07.2007 16:02:36 - C1L1D1T00 | BitrateDN: 5344 kbit/s | BitrateUP: 448 kbit/s | SNRM: 5.2 dB
19.10.2007 00:10:25 - C1L1D1T00 | BitrateDN: 2944 kbit/s | BitrateUP: 448 kbit/s | SNRM: 12.8 dB
20.10.2007 00:36:06 - C1L1D1T01 | BitrateDN: 2944 kbit/s | BitrateUP: 448 kbit/s | SNRM: 10.5 dB
22.10.2007 13:07:53 - C1L1D1T01 | BitrateDN: 3328 kbit/s | BitrateUP: 448 kbit/s | SNRM: 12.2 dB
27.10.2007 22:37:36 - C1L1D1T00 | BitrateDN: 3392 kbit/s | BitrateUP: 448 kbit/s | SNRM: 8.3 dB
27.10.2007 22:47:37 - C1L1D1T01 | BitrateDN: 3392 kbit/s | BitrateUP: 448 kbit/s | SNRM: 8.5 dB
25.11.2007 20:06:10 - C1L1D1T00 | BitrateDN: 1952 kbit/s | BitrateUP: 448 kbit/s | SNRM: 18.8 dB
25.11.2007 20:06:10 - ALARM (caused by trigger-value):|DN(3000)|| DSL-Resync is executed.
25.11.2007 20:06:29 - C1L1D1T19 | BitrateDN: 3136 kbit/s | BitrateUP: 448 kbit/s | SNRM: 12.4 dB
25.11.2007 20:06:29 - | Problem was SUCCESSFULLY resolved by Resync
25.11.2007 20:16:11 - C1L1D1T01 | BitrateDN: 3136 kbit/s | BitrateUP: 448 kbit/s | SNRM: 11.9 dB
25.11.2007 20:26:10 - C1L1D1T00 | BitrateDN: 3136 kbit/s | BitrateUP: 448 kbit/s | SNRM: 7.9 dB
25.11.2007 20:36:10 - C1L1D1T00 | BitrateDN: 2464 kbit/s | BitrateUP: 448 kbit/s | SNRM: 12.6 dB
25.11.2007 20:36:10 - ALARM (caused by trigger-value):|DN(3000)|| DSL-Resync is executed.
25.11.2007 20:36:29 - C1L1D1T19 | BitrateDN: 2176 kbit/s | BitrateUP: 448 kbit/s | SNRM: 12.1 dB
25.11.2007 20:36:29 - alarm trigger-values:|DN(3000)|| PROBLEM was not resolved by Modem-Resync!
25.11.2007 20:46:10 - C1L1D1T00 | BitrateDN: 2176 kbit/s | BitrateUP: 448 kbit/s | SNRM: 14.2 dB
25.11.2007 20:46:10 - ALARM (caused by trigger-value):|DN(3000)|| DSL-Resync is executed.
25.11.2007 20:46:29 - C1L1D1T19 | BitrateDN: 2560 kbit/s | BitrateUP: 448 kbit/s | SNRM: 12.2 dB
25.11.2007 20:46:29 - alarm trigger-values:|DN(3000)|| PROBLEM was not resolved by Modem-Resync!
25.11.2007 20:56:10 - C1L1D1T00 | BitrateDN: 2560 kbit/s | BitrateUP: 448 kbit/s | SNRM: 11.3 dB
25.11.2007 20:56:10 - ALARM (caused by trigger-value):|DN(3000)|| DSL-Resync is executed.
25.11.2007 20:56:29 - C1L1D1T19 | BitrateDN: 2464 kbit/s | BitrateUP: 448 kbit/s | SNRM: 12.0 dB
25.11.2007 20:56:29 - alarm trigger-values:|DN(3000)|| PROBLEM was not resolved by Modem-Resync!
Note : ive set it to resync if i get less than 3mbit because it should always stay at 3mbit or higher.
surely the isp capping me cant affect my sync rate at the exchange ?
Your SNR Margin (SNRM on that table) looks to be fluctuating a bit too much. Could be the cause of the speed problems. Looks like there is something on the line that is causing too much noise.
