whats wrong with my sn25p?
13 Feb 2003
It wont work :( Problems started in the heat from last week.
The first time it crashed and wouldn't boot, I unplugged the hdd, and it went to bios no probs. After the hdd had been in the fridge for a bit, plug it in, fire it up... working again \o/
A few mins later: crashed again :( Unplug the hdd, but I cant get to bios.
So the shuttle has been idle since today as the relatively arctic temperature of 27C has been reached. All bits together, booting up...freeze :( Now its doing the same as last time - even with no hdd plugged in (no cd or card readers either) absolutely nothing happens on the monitors. The fans on my 7800gt are spinning up though.
I have noticed the psu is now making a buzzing noise even when not turned on.
Opinions on what is wrong?
I don't have another pci-e to test the 7800gt. I have checked the hdd, it seems fine as a slave drive on this comp. Soooo, psu/graphics - where's you're money at?
Kinda hoping its the psu because the shuttle should still be in warranty. The graphics I bought second hand...
memory is 2x1gb geil value, the hdd is barracuda 7200.9, gfx is bfg7800gt oc.
edit: just reading up, looks as though I might not have warranty :/ bought it from the bay. was told it had manu warranty. It was sealed when it arrived so I left good feedback. can't find anything on shuttle.com that sounds good for me : /
Have you cleared the CMOS and reset the BIOS to defaults?
It might be worth noting that original SN25P had bad SATA cables so a quick swap out would be the first port of call. Second I would try checking it with a single stick of RAM and if possible test as much equipment as you can on a friends machine.
Sooner or later you will find the culprit. Good luck :)
Open it up and re-seat everything.
WHilst your doing this, reset Cmos and remove battery.
rebuild and give it a go.
Used to help mine when it got glitchy, that was till i blew it up :(
yea, I have previously cleared CMOS, and reset to defaults, but now it wont post/do anything. I cant get back into bios anyway.
I'm not pulling the cpu out again, because I only just had it out for AS5 application. nothing else is plugged in apart from the gfx, which has been in-and-out like a hokey cokey maniac on speed, and the memory.
I could give the memory thing a try, but I would put money on it not being the memory. :(
Well, that was a useful exercise - I tried both sticks in the blue slot on their own - both times it worked \o/ Tried both in at the same time, different ways around - :( Tried one stick in the black slot - :( didnt bother trying the other. It seems quite obvious whats wrong. Now to worry about if I can get an RMA
