Whats your opinion on the Fractal Design Define XL Full Tower Case for water cooling
Do you reckon you could get a quad/dual rad + fans in the bottom? A la TJ07? I prefer the look of this over TJ07 but wouldn't sacrafice rad space for it.
I'm set on a quad rad internal. Not too bothered about the dual. I could always put that up top. I'm only cooling a 6970+2500k. WOuld like to cool 2x6970+2500k though as will be adding another to the loop at Chrimbo time.
Yes, you could fit a quad and a dual and psu in the bottom, maybe a little tight for the pump in the bottom though, at the moment I have a quad in the bottom and psu and my pump and a double in the top and it works out really nice:)
here you go, I think it will look real nice once everything is plugged in and in place, also got to sort out the side panels yet.
well the case comes with a plate for the psu, I just used that on its side, had to dremmel some of the rear of the case to allow the airflow for the psu fan and exhaust of the psu
can we see a pic showing the rear of the pc showing psu?
Also on the second pic what is that blanking plate for that is in the vertical position maybe a dumb question?
Cheers mate, that was super helpful. I'd remove the HDD caddies as my HDD is in a scythe quiet drive (fits a 5.25" bay) and the SSD would also go into a 5.25" bay.
Where the HDD bay is, that's where I'd put the pump. I'm now going to see if it's worth getting this case + mods over the cost of the TJ07.
I'd have to cut out a window + side vents. I'd want to replace the top window with an acrylic window of my own too. Maybe use some more acrylic/alu to cover the drive bays, right down to the mid plate. Kinda like a TJ07. Only nicer :P
here's a pic of the rear where the psu is, it could be neater if i trimmed the bottom of the bracket and painted it up but i couldn't be bothered as it's out of sight anyway
here's round the back so you can see the vent for the psu which had to be dremmeled out.
