Whea uncorrectable error
28 May 2007
Saturn’s moon Titan
I can't play crysis. 2 or 3 bcoz of this error any ideas I've just got this bundle . All my other games are fine .
yeah when you use various apps to stress test the oc's you shouldn't get any 'whea' type errors in the event viewer otherwise one or more of your oc's isn't stable. Undo the oc's and then reinstate one at a time. So put the memory and gfx back to stock then stress test the cpu and check the event viewer afterwards. Then reintroduce the memory oc and rerun prime 95, again recheck the event viewer. Finally put the gfx oc's back and stress it in heaven and recheck the event viewer. At some point it should become apparent which oc is too high. Make sure temps aren't getting too toasty on cpu or gfx too since the weather is quite warm atm.
