Whea uncorrectable error .
28 May 2007
Saturn’s moon Titan
Any one had this error on Windows 10 I get when playing crysis 3 any ideas of a fix . Is there a Windows update fix? Anyone no off.
do you have any overclocks on the CPU? is the PC in question the one in your sig?
try and lower down the overclock or for a temp measure remove the OC.
has the issue happened before or was this the first time?
It means your overclock is not stable.
Either bump the voltage or drop the speed.
After a lot of testing and 35hrs of gaming I had a WHEA on Thur. So I bumped the voltage 0.1v.
Thanks lads for the reply I bought the bundle of overclockers all my other games run perfect just crysis 3 isn't stable I don't no nothing about overclocking to be honest do t want to fiddle about with it.
You are the man mate you were bang on. Post in the customer support and the fella told how to bump up the voltage thanks for your advice!
Regards scubes...
