Wheel advice
16 Dec 2009
Belfast
works for PC as well, (currently using my wireless xbox 360 pad) according to people on the logitech forums
Are you buying off a mate? if so try it out, make sure the FF works with you current OS.
I remember when I had a DFGT had to install as admin in Win7 compatibility mode on Win8 64bit, otherwise would recognise as a Logitech Momo wheel.
No not buying from a friend, just someone from gumtree
Another vote for the DF GT. Usually £40-50 secondhand.
Most of the Logitech wheels are PS2/PS3 and PC compatible. DF GT is fine.
Going to get the DriveFX today, see how that goes. Don't know if i will use it enough to warrant an upgrade, but if i did a DF GT would be the best one to get for a low price ?
