I had the wheel alignment/geometry checked over the weekend on the Octy vRS.
Was getting two new tyres and didn't want them going the same way as one of the old ones - scrubbing away at an alarming rate.
We had a bit of a discussion before starting.
I was going to have the new Falken's on the front and my two good Bridgestone's on the back.
We then decided to put my older Bridgestone's on to the front and the brand new Falken's onto the back.
Car up on the "Hunter" equipment, compares some 14 different measurements with the latest manufacturers specification.
5 of these settings were immediately flagged "Red" as well outside of manufacturers settings.
Guys spent about an hour making changes, bringing the reds back to manufacturers settings and also changing some of the "green" settings so they were closer to the revised manufacturers settings.
My car now feels like a completely different beast.
There is just so much grip there all the time, the car just feels so perfect around corners etc.
Cost me £25 for the initial Hunter scan.
Then £50 for the hours worth of labour to make changes and then another check, a few more adjustments and then the final scan.
If you are considering getting your wheel alignment/geometry checked I cannot recommend enough the "Hunter" equipment - it checks so much more and I feel the end result is going to be better than what you'll get at a normal tyre fitters.
To me it was worth every penny of the £75+vat it cost me.
