Posted this elsewhere but not had many replies
I am pretty sure I need to get my wheels aligned. When the steering wheel is centered the car heads off to the right a bit so to go straight the mitsu badge on the wheel needs to be pointing a bit to the left. I have also noticed under heavyish breaking the car is pulling strongly to the left which I assume would be another sign.
Now, the brakes themselves are seeming somewhat pants at the moment so I am guessing I will need new ones soon on the front, I am also not a million miles away from needing new tyres on the front.
The questions:
1) If I got my wheels aligned and then a month or so down the road got my brakes done or front tyres replaced, would that undo the worth of the wheel alignment in the 1st place?
2 Does each of the above points suggest I need it? I have assumed so but really am not mechanically minded so not sure if it might just need tracking sorted or if something else may make it pull to the left.
3)I have noticed over uneven ground the steering wheel tries to turn (often over a 3rd) without much resistance meaning I have to really hold on so to speak to stay on track. Would a wheel alignment sort this out or is it likely to be something else?
4) How much does laser alignment normally cost?
The questions:
