So, is this possible?
Basically, I have a heavy knocking noise from the front right, doesn't matter what speed, or whether driving on a smooth as glass surface.
I've had this before, every time I investigated it, the problem would go away and then come back after a few days. Eventually I replaced the brake pads and the noise went away and didn't come back for maybe 6 weeks, now it is back.
Now I've had the coilovers in bits and there's nothing to report there. It's had recent lower arms, bushes, tie rods/ends, all of them Meyle/HD (the noise was there before I changed all this stuff, and was exactly the same after).
So anyway, what I have noticed is there is play in both front wheels, both at 3/9 and 12/6. This would be indicative of knackered wheel bearings, right?
Previous experience of dead bearings is that they make a terrible droning/grumbling noise, but I don't have anything like that, only this constant knocking noise. What do you guys think, they are FUBAR?
