Nope. Don't use the steelie bolts on the alloys. The taper will damage the flat face of the alloy, as well as possibly puting you at risk. You'll most likely need longer bolts anyway. Get down to a peugeot dealer and say look these are the wheels I need the correct bolts for em.
well the alloys are slightly taperd but my steel bolts still dont sit flush so flat bolts are the way to go then yes? I've been to pug and they want £5 a bolt
