Wheel Help
9 Jul 2008
Bristol
Ok Guys,
In a bit of a pickle here. I have a Honda XR 125 L.
I need a second front Wheel ( I wane go green laning and need to swap between Road and Offroad Tyres).
I found a Back Wheel, so that is sorted, but I cannot find a Front Wheel for my bike anywhere.
The Front is a 19 inch with 90/90 tyres on.
Somebody suggested I would get a Honda XLR Wheel for it. The only problem is it is a 21 instead of a 19. Both my bike and the XLR use 240mm front disks.
Would it be possible to use the 21 inch with my bike? Also this is the old tyre size of 2.75. Anybody know what this would be in the new sizes? Something like 80/90 or 90/90?
If I had enough money I would buy a 2 Stroke 125 to take offloading, but at the moment the garage is full of junk (including my XR) and not enough money to have both bikes until end of this year.
Thanks for all your Help Cheers.
Have you ever thought about getting some tyre levers and changing the tyres yourself, I just changed my Funduro tyres myself with a pair of levers and some soapy spray, I can do both in about half an hour.
If you can't find the wheels then this is what you could do.
No not thought about that. I don't mind doing this on my bycial but don't fancy doing this everytime I want to change tyres. Would be easier to have 2 sets of wheels for hotswap :P
