OK - I'm not generally a 'believer' when it comes to exotic cables, so I'm not even going to go there
However, I just made a *really* audible difference to my PC set-up by changing some leads over.
My set-up is a Delta66, going to OmniStudio b/o box, going to WharfeDale Diamond 8.2 active monitors.
Previously I was using some 3 meter standard 1/4" jack -> jack connectors (guitar leads basically). Good leads too - one Planet Waves and one Piranha.
Today I replaced them with cheaper - but shorter cables, with different connectors. I'm now using two times 2 meter Lynx Professional 1/4" jack to XLR cables. They are very well shielded, and now of course I'm going into the XLR inputs of my speakers.
I simply can't believe the difference. The sound stage has opened right up, and the low-mids, which were a bit boomy before, have calmed right down
Clarity and transparency are now words I can use about these speakers - where before I was wondering whether I liked them or not (they are still breaking in as they are quite new).
Maybe it's the fact I'm using XLR now, which is a better connector, maybe it's the shorter cables providing less resistance, maybe it's the thick shielding (although this has more to do with rejecting RF I guess). Maybe a combination of all the above.
The moral is, if you have XLR connections on your gear - use them! Oh yeah - and shorten all your cables if possible. I've made quite a difference to systems by doing this in the past. Just not usually quite as large as today!
