- 14 Oct 2007
- newcastle
when you delidd a chip what do you stick the IHS back on with ? I have some liquid metal coming but don’t know what to use for the IHS
Probably 60-80c in that area and what the maker of the Delid tool says to use or Superglue Gel but does warn some peeps CPU's later came loose (I guess due to heat) damaged the CPU talking some PCB with it.
Also watch you do not apply too much making it near as bad as the Intel glue raising the IHS of Die and your choice of TIM.
No need to stick it back on with anything. The socket is good enough.
So the ones OCUK sell are just looseNo need to stick it back on with anything. The socket is good enough.
So the ones OCUK sell are just loose![]()
