When I press Ctrl, Alt, Del
26 Jan 2007
Surrey
I want to go straight to the task manager, instead of choosing whether I want to shut down comp etc.
How do i change this cause it was fine before i formated.
Thanks
Chunk
You've got Classic logon set up, I presume?
Switch it back to the Welcome Screen and ctrl-alt-del should do the trick.
Alternatively, Ctrl-Shift-Esc will do the trick. ;)
