hi,
At the very first post screen after is shows the bios version and type and before it detects the hdd and optical drive...it says "dual channel ram" unbuffered...
is that normal...
also when i switch on its beeps once and then loads up normally with the above msg...
just wanted to check if thats normal really? and if not what i am doing wrong
thanks in advance
cheers
is that normal...
thanks in advance
cheers
